5A05 Aluminum Sheet distributor
Notapor a104jx » Mié Mar 27, 2019 3:36 am
Company Introduction
EO Aluminum (Aluminum Products Suppliers) is a privately run company that originated from its parent company of 2002 in Shenyang, Liaoning EO Technology Co., Ltd.
EO Aluminum Company has perfect rules and regulations, access to a number of authoritative certification and qualification certificates.
Product Introduction
We distribute all kinds of aluminum products from our main warehouse located in Shenyang, and from other warehouses in different cities in China to all over the world. We have a wealth of material resources and mature professional production technology.
For aluminum products we can produce aluminum raw materials: aluminum sheet/plate, aluminum bar/rod, aluminum tube/pipe, aluminum disc/circle, aluminum coil, aluminum foil, aluminum strip and so on. We can also produce aluminum profiles for building and industries and other fields. Such as aluminum windows and doors, aluminum heatsink, aluminum frame and so on.
Product Application
Aluminum is also theoretically 100% recyclable with no loss of its natural properties. It also takes 5% of the energy to recycle scrap aluminum then what is used to produce new aluminum. The most common uses of aluminum:
Transportation
Aluminum is used in transportation because of its unbeatable strength to weight ratio. Its lighter weight means that less force is required to move the vehicle, leading to greater fuel efficiency. In aerospace, automotive, marine fields aluminum has very important use.
Construction
Buildings made with aluminum are virtually maintenance free due to aluminum’s resistance to corrosion.
Electrical
Although it has just 63% of the electrical conductivity of copper, aluminum’s low density makes it the best option for long distance power lines.
Consumer Goods
Smartphones, tablets, laptops, and flat screen TVs are being made with an increasing amount of aluminum. Its appearance makes modern tech gadgets look sleek and sophisticated while being light and durable.
Transportation Service
Aluminum profile in the transport process must be handled lightly, prevent bump caused by surface injury, affect the appearance of the surface. EO Aluminum has many marine air transport Logistics partners, can make the goods safe and fast arrival destination, professional technical guidance and product services, to ensure that customers’ satisfaction, let cooperation upgrade.
website:http://www.eoaluminum.com/
a104jx
