Longspan Shelving Made in China
Notapor a104jx » Mié Mar 27, 2019 3:40 am
DIY home use racking also called Z rivet racking, Boltless rack, no nuts or bolts required.Mainly for home use, office and so on.
Z beam rivet shelving is type of shelving, usually in stand alone units, that is assembled without nut and bolt fasteners. The idea behind the design of boltless shelving systems is to provide an easily adjustable and quick-to-assemble shelving unit. Many types of boltless shelving are available,utilizing a number of different designs both for assembly and for basic structure, some of which rely on the hardware and assembly methods to provide strength to the overall structure as well as to simply hold the pieces together.
Z beam rivet shelving Features:
1) Post: OTS special one-time stamping cross, high strength, good aesthetics.
2) Z beam: OTS special tie sloping ribs type and have a high carrying capacity.
3) Cargo storage ways: Manual storage.
4) Rivet racks advantages: You can DIY, can be arbitrarily assembled to meet the needs of different environments.
5) Boltless rack standard dimensions: 915/1830/2745(h) x 910-1220(w) x 400-700(d)mm(Large quantity can be customized).
6) Shelf quantity: 5 (extra shelves available).
7) Shelf Load: 250 Kg UDL per shelves.
8) Colour: Grey or customized.
9) Laminates:MDF board,steel panel,wire mesh.
10)Installation Tools: Only a rubber mallet is needed (no nuts or bolts required). Simple to build, constructed within minutes.
Boltless racking details:
Z beam rivet shelving to indicate:
Z beam rack customer cases :
We are one of the leading shelving suppliers in China, equipped with a professional and productive factory at your service. If you are interested in our Z rivet racking, welcome to place orders. They are all in line with the standard of CE, ISO9001, Q235B, RMI, AS4084 and Q345. And the customized orders are also accepted.Longspan Shelving Made in China
website:http://www.otsrack.com/longspan-shelving/
a104jx
