Características aqui:
http://www.kenwood.eu/products/car/ampl ... KAC-8152D/
Tiene un roce como puedo apreciarse en las fotos.
Amplifier Features
Class D Amplifier Yes
Load Capability 2Ω Stable
Maximum power output 1100W
Rated power output (4Ωt 300W x 1 (4Ω
Rated power output 550W x 1 (2Ω
Low-pass Filter Yes
Bass Boost Circuit Yes
Infrasonic filter Yes
Phase inverter 0°(Normal) / 180°(Reverse) Yes
Power Indicator Multifunctional
Line in 1 RCA (Gold Plated)
Line out 1 RCA (Gold Plated)
Speaker level Input Yes
Removable Coverplate Yes
Yes
DC cable Supplied No
Amplifier-Specifications
Maximum power output (4Ω 1100W x 1
Rated power output (4Ω, 14,4V) 300W x 1 (20Hz ~ 200Hz, 0.5%THD)
Rated power output (2Ω, 14,4V) 550W x 1 (100Hz, 0.9%THD)
Low-pass Filter 50~200Hz (24dB/oct)(B-Channel)
Bass Boost Circuit 0~18dB/oct
Bass Boost Frequency 40Hz ~ 100Hz (Variable)
Infrasonic filter 15/25Hz (18dB/oct)
Input Sensitivity 0.2 ~ 5V
Input Impedance 10kΩ
Signal to Noise Ratio 96dB
Frequency response (+0dB, -3dB) 5Hz ~ 200Hz
Operating voltage 14.4V (11V ~ 16V allowable)
Maximum current consumption 40A
Installation Size (WxHxD) 380 x 61 x 286 (mm)
Weight 5.6kg
