Si estás interesado en una CPU Core 2 Duo, aquí tenéis uno, con poquísimo uso, en perfecto estado.
Es un Compaq Presario SR5619, con las siguiente especificaciones técnicas:
* Monitor de 19" (GB144AA):
* PC de sobremesa (NF418AA):
Procesador Intel® Pentium® Dual Core Processor E2220 (1M Cache, 2.40 GHz, 800 MHz FSB)
Memoria RAM 4 GB DDR2
Disco Duro 250 GB
Sistema Operativo Windows Vista Home Basic
Unidad Óptica DVD±RW LightScribe
Lector de tarjetas de memoria "15 en 1"
Lan Tarjeta de Red (10/100)
ESPECIFICACIONES
Hardware
Base processor
Pentium E2220 (C) 2.4 GHz (65W)
800 MHz front side bus
Socket 775
Chipset
Intel G31 Express
Motherboard
Manufacturer: MSI
Motherboard Name: MS-7525
HP/Compaq motherboard name: Boston-GL6
Power supply
300W
Memory
Component Attributes
Memory Installed 4 GB
Maximum allowed 4 GB* (2 x 2 GB)
*Actual available memory may be less
Speed supported PC2-6400 MB/sec
Type 240 pin, DDR2 SDRAM
Hard drive
250 GB SATA 3G (3.0 Gb/sec)
7200 rpm
16X DVD(+/-)R/RW 12X RAM (+/-)R DL LightScribe SATA drive
Must use Double-Layer media discs in order to take advantage of the DL technology
Must use LightScribe-enabled media discs and supporting software in order to take advantage of the LightScribe technology
Function Maximum speed
DVD-RAM Up to 12X
DVD-R DL Write Once Up to 8X
DVD+R DL Write Once Up to 8X
DVD+R Write Once Up to 16X
DVD+RW Rewritable Up to 8X
DVD-R Write Once Up to 16X
DVD-RW Rewritable Up to 6X
DVD ROM Read Up to 16X
CD-R Write Once Up to 40X
CD-RW Rewritable Up to 32X
CD-ROM Read Up to 40X
Video Graphics
Integrated on motherboard (see motherboard and chipset)
Sound/Audio
High Definition 5.1 audio
ALC 662 chipset
Network (LAN)
Integrated 10/100 Base-T networking interface
Memory card reader
Supports the following cards:
Compact Flash I
Compact Flash II
IBM Microdrive
Secure Digital (SD)
mini-SD
MultiMediaCard (MMC)
Reduced size MultiMediaCard (RS-MMC)
MultiMediaCard Plus (MMC plus)
MultiMediaCard Mobile (MMC mobile)
Memory Stick
Memory Stick Pro
Memory Stick Duo
Memory Stick Pro Duo
SmartMedia
xD Picture Card (xD = extreme digital)
External I/O ports
I/O ports on the front panel
Port type Quantity
15-in-1 (4 slot) One
USB Two
Headphone One
Microphone One
I/O ports on the back panel
Port type Quantity
PS2 (keyboard, mouse) Two (one each)
VGA One
USB Four
LAN One
Audio (line in, line out, microphone) One Each
Expansion slots
Slot type Quantity
PCI One (One available)
PCI Express x16 One (One available)
PCI Express x1 Two (Two available)
Drive bays
Bay type Quantity
5.25" Two (One available)
3.5" One (None available)
Keyboard and mouse
Compaq PS/2 keyboard
Compaq PS/2 optical mouse
Se vende junto con el monitor de 19" panorámico. El PC tiene un año y medio, y no se ha utilizado apenas. Se puede entregar formateado, o con Windows 7 Ultimate activado. Se vende por falta de uso, ya que entre el iPad, y el portátil, y que cada día paso menos tiempo en casa, me da pena tenerlo ahí parado.
El precio, sería de 280 € en mano en Madrid, o 300 € enviado.
