[VENDO] Ordenador de sobremesa (se vende por falta de uso)
Notapor mdcostas » Dom Ago 18, 2013 3:48 am
Vendo ordenador de sobremesa por falta de uso, funciona correctamente. A continuación se detallan los componentes:
Placa base ASUS M2N68-CM
AMD® AM2/AM2+ CPU Support up to 140W
Dual-Channel DDR2 -1066/800/667
5000 hrs VRM solid capacitor
Support Dual-VGA output:DVI & RGB
Instant Internet Access with Express Gate
Support 45nm Phenom™ II CPU
Especificaciones: http://www.asus.com/Motherboards/M2N68CM/#specifications
Procesador AMD Athlon™ X2
Processor AMD Athlon™ X2
Model 5050e
OPN Tray ADH5050IAA5DO
OPN PIB ADH5050IADOBOX
Operating Mode 32 Bit Yes
Operating Mode 64 Bit Yes
Revision G2
Base Speed (MHz) 2600
Boost Speed (MHz)
Voltages 1.0-1.25V
Max Temps (C) 78'C
Wattage 45 W
AMD Virtualization Technology Yes
L1 Cache Size (KB) 128
L1 Cache Count 2
L2 Cache Size (KB) 512
L2 Cache Count 2
L3 Cache Size (KB)
CMOS 65nm SOI
Socket AM2
AMD Business Class No
Black Edition No
Especificaciones: http://products.amd.com/pages/desktopcpudetail.aspx?id=487
Memorias OCZ OCZ2RPR800C44GK / 4GB DDR2 PC2-6400 800 MHz / Reaper HPC Edition / Dual Channel Kit / CAS 4
800MHz DDR2
4-4-4-15(CAS-TRCD-TRP-TRAS)
Available in 4GB (2x2048MB)Dual Channel Kits
Unbuffered
OCZ Lifetime Warranty
2.1 Volts
240 Pin DIMM
Especificaciones: http://ocz.com/consumer/company/newsroom/press/ocz-technology-answers-enthusiast-demands-for-a-complete-high-end-memory-solution-with-the-4gb-reaper-hpc-cas-4-edition
Placa de video ASUS EN8400GS/HTP/512M(LP)
Incredible gaming experience with PCI-E 2.0 & DX 10 support!
Efficient Cooling Fan: Dissipate the heat quickly
HDCP Compliant
ASUS Splendid
Especificaciones: https://www.asus.com/Graphics_Cards/EN8400GSHTP512MLP/#specifications
Fuente de alimentación ANTEC EA-500D SKU: 0-761345-27500-2
80 PLUS® certified: reduces operating costs and protects the environment
80mm low noise cooling fan
Dual 12V outputs
Industrial grade protection: OVP (Over Voltage Protection), UVP (Under Current Protection), SCP (Short Circuit Protection), and OPP (Over Power Protection)
Accurate power rating allows EarthWatts to deliver its full rated power
4 SATA connectors
PCI-E connector: one for 380W and 430W, two for 500W
Safety approvals: UL, CUL, FCC, TÜV, CE, CB, C-tick, CCC, BSMI
Universal input
Active Power Factor Correction (PFC)
PF value up to 99%
Dimensions:
- 3.39"(H) x 5.91"(W) x 5.51"(D)
- 8.6cm (H) x 15cm (W) x 14cm (D)
Net weight:
- 3.48lbs / 1.58kg
Especificaciones: http://store.antec.com/Product/power_supply-earthwatts/ea-500/0-761345-27500-2.aspx
Lectora Samsung DVD-ROM 16x, Black + Power DVD (SH-D163B/BEBP)
Referencia Samsung DVD-ROM 16x, Black + Power DVD
Montaje Vertical/Horizontal
Memoria temporal 0.5 MB
Interno Sí
Interfaz Serial ATA
Número de discos 1
DVD velocidad de lectura 16 x
Dimensiones (A x P x A) 148.2 x 170 x 42 mm
Color Negro
CD velocidad de lectura 48 x
DVD-R, velocidad de lectura 16 x
CD-R, velocidad de lectura 48 x
CD-RW, velocidad de lectura 48 x
Software incluido Power DVD
Especificaciones: http://www.samsung.com/es/consumer/pc-peripherals-printer/odd/dvd-rom/SH-D163B/BEBE-spec
Torre Thermaltake Soprano Dx Case
Dimensions 497 x 210 x 478 mm (L x W x H)
Material 0.8mm aluminium body, aluminium front panel
Weight 6.09kg
5.25in external 4
3.5in external 2
3.5in internal 5
Expansion slots 11
System fans 1 x 120mm (blue LED) and 1 x 140mm
Water-cooling preparation No
Model variants Four - 2x black, 2x silver, each with/ without window
Manufacturer code VE7000SWA
Especificaciones: http://support.thermaltakeusa.com/Product.aspx?C=1433&ID=1449#Tab1
Disco duro Seagate Barracuda 7200.12 160 GB (ST3160318AS)
Capacity: 160GB
Spindle Speed: 7,200RPM
Interface Type: SATA
Disk Size: 3.5"x1.0" (Low Profile Hard Drive)
Sustained Throughput (MBps):
Average Seek Time (read/write ms):
Electrical Interface Speed: SATA 300 - 3.0Gbps
On-Board Cache: 8MB
Especificaciones: http://www.seagate.com/files/docs/pdf/es-ES/whitepaper/7200-drive-spec-comparison-es.pdf
Como ya comente al principio, lo vendo por falta de uso (tengo otros dos y este vivía mas apagado que encendido) y lo entrego completamente montado.
Se entrega en la caja original de la torre.
Vivo en Seseña (Toledo) pero trabajo por Madrid y la entrega seria en mano, pero si alguien esta interesado y es de fuera de Madrid se podría enviar, corriendo con los gastos del envío el comprador.
El precio de venta es 120€.
Si necesitáis mas información no dudéis en preguntar.
CITROËN C4 1.6 16V Collection
mdcostas
Re: [VENDO] Ordenador de sobremesa (se vende por falta de us
Notapor mdcostas » Lun Sep 02, 2013 22:01 pm
up.
mdcostas
Notapor mdcostas » Jue Oct 10, 2013 19:47 pm
VENDIDO.
Se puede cerrar.
mdcostas
